DR rendering, all machines using one core only
I was wandering if you guys could help me.
We are trying to render on multiple machines in our office using DR method, however all machines render using one core only. I found out that there is 10 machines limit per licence so theoretically I should have 20 buckets on my screen (all computers are dual core).
Did anyone have similar problem? I would really appreciate your help.
*** rubbing my glassphere
you are using max9 and Vray RC3
before you render press F11
type in
renderers.current.system_numthreads=2
that should give you back a blue 2
if you render now all pc use 2 cores to render
thats bug in vrayRC3 - go for the update !
Actually, it’s a bug in 3ds Max… but you can work around it as QuakeMarine1 posted. For newer versions (e.g. 1.5) V-Ray automatically does something similar to force multithreading.
Thanks QuakeMarine1
Checked and it didn’t work.
I forgot to add in previous post: I’m using max9 64bit and Vray1.5 RC3
checked it again and it worked:)))
I guess I was doing something wrong.
Thanks again QuakeMarine1.
