DR sending the wrong max file to slave machines
First of all we’re loving Corona, so thank you all very much.
However I’m attempting to process using the DR but it seems to be sending an old max file to the slave machines. The file I’m working on is a large file 360mb and set to process at 4000x2250 pixels.
The file the DR slaves are receiving is an old file of a previous project and completely unrelated to the current project. I opened up the max file it said was received and this confirmed it was a very different file.
Has anyone had and resolved this issue before? Do I simply need to somehow purge the DR queue? If so how?
Thanks very much.
Andy
hi,
try deleting the drdata folder first on the slave, to confirm that the file really got transferred, and it is not previous file already present on the slave machine
Thanks for the quick reply.
We’ve just tried that, but when the slave is restarted it still receives the wrong file (same as before) from the host machine.
Andy
can you update DR server and corona on all machines to the latest daily and try again? There were some fixes related to your problem. You will find them here: Dropbox - Error - Simplify your life - folders “2015-03-24”. Instructions: Daily Builds 1.0 - 1.4 - Corona for 3ds Max :: Previews (Daily Builds) - Chaos Forum
have you tried updating your build? THere were some new checks added
