DR slaves disconnect
I’m rendering a 200 frames sequence using the new animation prepass mode in irrad map and distriubuted rendering.
My master is 64 bits, one slave too and one slave 32 bits.
The 32 bits slave have no problem, but the 64 one crash often. I have to restart the DR spawner to make it restarting render (great new stuff)
Is anyone have a solution?
Thanks.
If you can get me a vraylog.txt file on the crashed machine right after the crash, I will be able to tell you more about the issue; not sure what might be causing it right away.
Here is the logs files of the 32 bits machine that just crash.
http://www.edge-fr.com/vraylog.zip
and here is the logs for the x64 machine just after a crash.
http://www.edge-fr.com/vraylog64.rar
Anything on this issue? Same one we had the other day.
