I think I might have found a new bug.
I installed Vray on two servers (Win2003 Server x64) as Slaves. For whatever reason, I used the “registered DR spawner service” on one, but simply dragged the “launch DR Spawner shortcut” to the Startup folder on the other. Then when I did a DR render the one with the registered service wouldn’t render any textures, while the other server did.
Both had equal access to my mapped textures folder. I could read the textures from both machines manually and using Backburner.
So it occurred to me that the only difference between the two was that one had the spawner registered and the other didn’t so i unregistered the spawner and launched it manually and that fixed the problem.
Is this a known issue?
