i got a virtual drive set up for all my shared maps, si i can have the same virtual path at home and at the office.
when i render in DR on my rendering slaves (which also have the same virtual path), DR is still transferring missing maps, even if they are actually accessible from the slaves.
Hm, if V-Ray transfers the assets, then it couldn’t really read the textures on the slave. What happens if you turn off the “transfer missing assets” option and turn on “check for missing assets”?
Unfortunately it will be difficult to say if the issue is somehow related to our plugin without reproducing it here.
According to your last update it works as expected on a new scene file. Does it help when you merge the scene into a new file?
