I wanted to share with you my very first ever animation short in the Archviz field, named ‘Duality’, it is a personal project that I made to demonstrate both the potential of Real-Time/GPU rendering, and the concept of populating the same space with the same decorations in two contrasting styles, light and dark, blue and red, while achieving elegance and harmony with each style.
I created this animation using 3DsMax/VRay and rendered in Vantage. (And I have few feedback and bugs to report about Vantage, not sure if to share them here or on the Vantage’s section of the forums!)
I hope you like it, and feel free to provide me with your feedback, I’d truly appreciate it.
Thanks… I picked one of DaVinci Resolve’s preset LUTs, but maybe I’m not using the proper workflow!, I’m still experimenting with things.
This is actually part of my feedback that I have about Vantage, I didn’t have the same level of control over the output as what we have in the VRay Frame Buffer!
I went with the default output PNG and that didn’t provide the flexibility I needed in Resolve, and I couldn’t adjust them in Vantage after the render like we can with the Frame Buffer, for example I couldn’t adjust the Lens Flare effect after rendering!, I believe you have to re-render!.
Lesson learned the hard way is that for now I needed to run some tests from start to finish across the entire process before rendering final. But I got as close as possible to the look and feel that I was aiming for.
Vantage is so fast, testing is quick. No longer do we wait hours to find issues, just to wait hours again. Heck, I remember coming back in the next morning to find errors that I had to correct.
Yeah, it is feeling too shiny and plastic but maybe that’s the trade-off with Vantage. More variation in glossiness values would help immensely, together
with good normal maps and general noise to break up the surfaces but I guess you know that already.
Overall a well thought out piece though. Good modeling/staging and general shading balance/lighting, good pacing of the camera work and editing with the music.
I’m not sure about the focal length animation, as it’s a bit extreme and stretches things a bit much and yes, that window bloom needs sunglasses
If you arent baking in ACES or a LUT, or any kind of tonemapping, you should render unclamped (linear) exr files, and do you tonemapping in post. You cant do anything with those overexposed areas with a png.
Yeah, at first I thought I’ll be able to easily adjust things in post (VRay spoiled me too much) but then quickly realized that I have few control and had to do away with what I got, also VRay GPU renderings looks way different than Vantage GPU renderings!, I really hope we can get some consistency between the two, or just have Vantage render technique and speed built-in VRay!, that would be an awesome addition to VRay.
The DoF shots are so few, I think you mean the ‘Vertigo Effect’ at the last shots, that involves shifting the FoV while dolly in with the camera, I thought it would give a sense of dramatic ending.
Found out the hard way after I finished rendering more than 9000 frames XD, as I had to render many frames to have longer times to be able to pick the right moment when editing, so, there is like 1 or 2 seconds extra before and after ever shot rendered with the cameras animations.
And since it’s my first time, I forgot to test with a sample shot first, going through the entire process and in to post to see the finalized output, just went straight to rendering…
I still need to test though, is rendering sequences in EXR will be easy to adjust in post?! Like, when dealing with the entire sequence and not just individual frames.
Thanks, I really appreciate the kind words and the feedback.
As my first animated output in Archviz, I’m really happy with the results, and I’ll keep experimenting around with the tools to figure out the proper workflow, hopefully that will improve upon the current level for next projects.
