Ok I’ve had a search but cant really find what I’m looking for. I’m sure I’ve seen how to do this before but how do you guys blend your sky to the horizon? Like maybe on an oceanscape or large plane.
Alas all of my work has been inside up untill now ![]()
Try an VRayPlane as ground or water surface
Fermí
Oooh yeah, should have said. I did try that but am using displacement. The pair don’t seem to play very well!
Displacement and VRAY planes area no go, but what you can do is put a displaced plane up close to the camera and then a Vray plane that blends into the horizon. Fog is needed too to get a good blend.
put the VRay plane a bit lower than your ground or sea in the foreground and give it a general noise colour to match your displacement object in the foreground?
Thanks guys, I’ll try blending the vray plane in somehow. Fog looked good but only when not using the physical camera…then the fog comes out black!?
