DWG Blocks
Hi people,
Just a quick question, when i import acad files into maxi gebin to edit the drawing by deleten all the stuff that i don’t need.
Problems is when i try to delete “block” my drawing get messed up.
i tried unlink, dwg clean script. but that does not work.
any1 has an idea how to get rid of those blocks?
cheers
Explode prior to importing?
Somebody did a script on cgarchitect to sort this. Do a search for ‘block’ and ‘dbarc’ perhaps over there…
Aaah cool m8, found a script thats seems to work reasonable… thx.
if any1 also is in search of this:
http://www.cgarchitect.com/vb/7726-autocad-blocks-max.html
Re: DWG Blocks
I actually use a script called “DWG Cleanup” by Jon Seagull to do this…
The way I do it is explode everything, purge and audit and then save before importing. On import I select to load everything as one model.
But then again, I draw everything in Max and only use facade views as reference.
If the dwg is just for reference I like to use file link, that way when I’m done with it lust detach and all the layers and blocks are gone.
