Editing 6:1 Cube renders for VR
Fusion!
This is a render made up of a background pass (top left), raw light comp, bg glass 1, and bg glass 2, then on the bottom row we’ve got foreground, a composite, foreground glass and some extra effects and color correction.
the mutimattes are the green ones along the top line of each box going into a color correct or curves adjustment.
The benefit of this is that you can do the postwork on a normal 35mm camera looking ahead in photoshop, convert it to fusion, then relink all the inputs to the newly rendered 6x1 files and everything will automatically be correct. once you’ve decided the blue in multimatte 6 should have these adjustments, you’re good for any future revisions.
If I were to animate this or move some geometry around updating the postwork is about 15 minutes work.
