Hi
Does Vray 3.3 for maya supports render with correct stereo for VR headsets or we still need to render 360 degrees images (1 degree at time) and stitch them together?
Thank you
Obrad
Hi
Thank you
Obrad
We do support spherical stereo panoramas, yes. There is no need to do the 1 degree trick.
Thank you Vlado. One more quick question are you guys planning to fix Cube 6x1 render with AA filter on (at moment Vray is filtering seams)?
Yes, but in the meantime you can simply turn off the filtering.
