I have a pretty heavy scene: forest pack (grass, pebbles, trees, bushes, flowers…), railclone (roof), displacement (bricks), environment fog and some complex procedural materials. When I render the scene at a resolution of 2K without the vraydisplacement everything is fine. But when I render with displacement and at 4K (also lower color/noise thresholds for AA and DMC) I get this message:
“Error building embree static ray caster, error message: memory allocation failed.”
And as a result most of my geometry isn’t being rendered (by the looks of it only things related with vrayproxies are actually showing up in the render: trees, bushes, roof,…)
I have 64GB of RAM
I just render to the Vrayframebuffer. And Static geometry has been ticked in my vraydisplacementmod.
Well I figured it might have to do with the static geometry, rendering at 2K as we speak without static geometry ticked (noise threshold still low though). Takes a while until LC is finished now though, but before that it took a long time converting vertices and my memory went through the roof. Well see if it renders fine at 4K with lower noise.
