Enhance vrscene support from V-Ray Next SketchUp / Rhino.
Enhance vrscene support from V-Ray Next SketchUp and Rhino.
Is it possible now including UV?
Hi, flat
What do you mean by “Is it possible now including UV?” If there are UVs on the mesh in SketchUp / Rhino then they should be imported. Please give more details.
Alexander
SketchUp can not create UVs suitable for light map bakes.
Therefore, to generate a lightmap with SketchUp vrscene, it is necessary to generate a lightmap UV on the V-Ray side.
Does the current V-Ray for Unreal solve it?
Hi, flat
Unfortunately no, V-Ray for Unreal doesn’t create UVs. This problem with lack of proper UVs is concerning Sketchup, Rhino and Revit and we are aware of the issue and researching the matter.
Alexander
