Enscape / ArchiCAD BLACK SCREEN
This has been happening more and more… It’s may just be a MEMORY issue… But I wanted to discuss here…
  • Call up 3d in ArchiCAD (notably, with plants and high poly count)
  • Open up Enscape
  • Save IMAGE… first image works just fine.
  • Move view
  • Image looks FINE on screen
  • Save IMAGE again and screen turns BLACK and will NOT complete the rendered image.
  • Hit ESC KEY and the image shows correctly again
  • Will NOT save image after this… Must shut down and restart…
I have a 1070ti Graphics card…
If there are no PLANTS involved, I can get more renders in before this happens (20 or 30)…
Sometimes it NEVER quits on me…
Let me know if anyone has experienced this and any potential fixes / work arounds.
The same thing is happening to me, so your not alone
@DGD-Duane , @Nuge - what version of Enscape are you using? As I need to know this to test it.
Also the ArchiCAD version, 21 or 22?
AC22 for me
AC 22
Enscape 2.6 11119
@DGD-Duane , @Nuge - this has apparently been fixed in this version of Enscape, which is one version on from 2.6.11119.
Can you please try that and get back to us if the issues persists?
Update:
I did about 35 render images today…
It went to the BLACK screen at about image 30 (made it further than before)…
But … this time… the black screen only held for 10+ seconds and then displayed the scene and rendered the image…
FOOTNOTE: at the time when the screen went black, it did show an anomaly in the lighting. Any light cast onto a wall looks like it is being shone thru a grid… see image below.
HA! it’s not just me that gets this lighting anomaly :slight_smile:
Yup… This has been happening a lot… Again… seems to be after a session of many images saved..
Originally I had just created a GRIDDED GLASS material and thought it was somehow pushing light thru that (even though the gridded glass was not near the lights location)…
But it happens in all my files eventually (again as enscape gets “TIRED”)…
@DGD-Duane - Would you be able to provide the project file that is causing you this issue? It may be helpful for the developers.
I tried to recreate the issue myself, but failed thus far.
I’ll PM you so you can reply with a link for the project and details of what else I need, if that’s ok with you?
I thought we were done for good with this grid-shadows-behavior :frowning:
