Enscape is crashing on me when I try to render a scene.
I sometimes get 2 or 3 renders successfully, then the next one crashes without any setting changes.
This is frustrating.
I have an amazing Nvidia gpu and workstation, so my hardware is capable. Perhaps with the new enscape version there is a bug or another setting that in need to tweak.
My Revit has the hotfixes installed and i am using the latest Enscape as well.
Enscape did just email me with a reply, and they mentioned there is a bug within Enscape that they hope to have fixed in the near future.
In the meantime they suggested using scope box in revit to reduce the elements being factored into the render, which did work for me in this case. It is a large revit model so that makes sense. I also turned off the exterior landscaping assets since i didnt need them for the interior render. The second tier of work around was to reduce the resolution from Ultra to High, but i didnt have to do that in my case. The scope box strategy did work.
Since, and I quote from the Production Branch drivers description “This driver was previously named, Optimal Driver for Enterprise (ODE), and is most commonly deployed in production systems at enterprises.” we also recommend going with those.
@DPHORVATH_1 - This type of crash is generally due to a lack of VRam. You can test/confirm by opening your Task Manager and looking at your GPU “Dedicated GPU Memory” This is found under the Performance tab. If you’re close to maxing out your PC’s VRam before render time you will most like crash as Enscape uses a bit more during the export depending on your Visual settings.
