Enscape Exported exe file WalkMode vs Fly Mode
AArrghh…..I was given an exported Enscape.exe file from Revit 2019. I am using Windows Mixed reality headset. In the headset I select walkmode in the menu and it instantly defaults to flymode. I have checked on the laptop that the model has walkmode selected. back in the headset and it will not allow walkmode. Very frustrating. Any ideas?
This should not happen. However, walkmode switches to flymode if you fall under the building to prevent you falling to infinity. Other than that, you should be able to toggle it. Can you show a video?
Thomas that makes perfect sense. I was given a model that is floating in infinity.
