Not bad at all for a first try
Maybe a silly thing to nitpick, but having been there myself, I can say that your site context is not very close to the real thing.
There is a bit of an open field like area beyond the house, and the trees in the foreground are much different as well.
If you wanted a more realistic image, maybe check out the context in google earth!
Overall quite nice though, is this your own model? Or something found online?
… in this house I do not want to stand under the shower, realizing that the all the towels are in the laundry ![]()
A great “First Time” :thumbup: :thumbup:
Thank you for comment. Almost all of model from 3dwarehouse. Except the house model, I forgot where I downloaded from.
I’m just curious if the material of the cabinet is changed like that, the length of the grass is added, the tree in front of the house is also with other models, not wanting to compare but just curious as to what, but the building is quite satisfying. I almost forgot, you can add 1% line rendering setting to outsmart the depth of white objects. Picture below only example. You can see the different with 1% and 0% line rendering when you zoom out it almost make more clear picture. Not compareing the shadow and compare to different picture. i just want to show when you use the 1% line rendering it will make a different please try it.
Thank you for your tip. That’s very useful.
