Enscape VRscene file material issues
We’re having problems with materials in our .vrscene exports from Enscape in 3DS Max Vray 6 and Vantage. We are seeing mixed up materials on objects and we are seeing materials that don’t translate correctly (too dark/light).
Can anyone suggest best practices for getting materials to export correctly to vrscene files from Enscape?
Thanks very much!
Hi, we would need a bit more details.
What is the host application for Enscape?
What is the export version of the file that was created during the export? You could open the .vrscene file in a text redactor and you can see this information in the header.
Can you share the problematic part of the scene? (Original scene). Maybe some images for comparison between the applications. You can do this through our support portal. Please add a link of this thread when you submit the materials.
Thank you.
Dimitar
