Enscape with Oculus Quest2
i got enscape vr working on my oculus Quest 2 with steam, steam vr and a usb 3 cable.
Are there any tips to improve the picture quality in my headset? Currently it´s not that good.
Thanks in advanve
Theresa
Welcome to our Forum @tkimgang , please kindly allow me to copy a fitting answer to basically exactly this topic:
Right away please ensure that DLSS is disabled in the Enscape General Settings → Rendering tab. DLSS works great on a 2D monitor, but it does make the image blurry in most cases inside of VR. If that doesn’t help, please also check your Oculus resolution setting - Should you then still be unsuccessful, can you confirm that this only occurs with Enscape?
If so it would also be helpful to receive a few screenshots from your scene (taken with a smartphone from within the glasses usually works).
