Environment Fog bug, unable to exclude lights as mentioned in the help docs
Easy to recreate,
1) Add Environment Fog
2) Add two lights
3) Drag one of the lights into the Environment Fog object (as per documentation)
4) Hit render
Both lights end up interacting with it.
I’ve tried everything, adding container object into environment fog object, attempted to use Exclude feature from the light.
No matter what, all lights in the scene interact with it.
Only way to stop a light from interacting with a fog is to disable ‘Diffuse’ check box under light Options tab.
Hi @imdb , this indeed is a bug on our end. I have logged an issue (VC4D-985) and we will try to fix this soon. Thanks for your report, we will update this thread once this is fixed.
Hello @michael_heinz1 ,
Generally, only polygon objects should be placed as children of the Environment fog and it is expected that the lights are not rendered once placed as children of the fog. We will be changing the way the lights are included/ excluded from the fog and I will let you know (and update our documentation page) once this is done.
Thank you for your patience and understanding.
Thank you very much @aleksandar.kasabov
Much appreciate it! will looking forward to the improvement.
