We’ve been running into the issue of receiving the following errors (see images) when we try to utilize Envision Live Link with Revit 2025
We’re trying to understand:
What this error means
How we can fix it (if it’s an issue with a rogue object or material, we just need to know how we can track down and fix/remove what is causing the issue)
These errors occur with Autodesk Revit Cloud projects, and we’ve seen this issue with multiple projects.
Hi, this is a known bug and it is usually related to light objects. Unfortunately it is very hard (or impossible) to find out which specific objects are causing this without developer superpowers.
We will then do our best to find the problematic objects for you ASAP.
Alternatively, you can wait a bit as this bug is already fixed internally and the fix will be a part of the upcoming version of Envision. If all goes according to the plan, it will be released very soon.
The root cause of this error message is a bug in Enscape, which leads to incorrect exports of Revit families that include multiple light sources.
This bug has been fixed internally, and a new version of Enscape containing this fix will be released soon. If everything goes according to plan, the release should occur within the next two weeks. Once it’s available, the solution will be to simply install the latest version of Enscape.
In the meantime, a workaround is to avoid using families with multiple light sources (nested lights). Possible options include:
Removing those objects completely,
Replacing them with families that contain only a single light source, or
Editing the families in question to manually reduce the number of lights to one.
We understand that the workarounds provided may not be ideal and could be unfeasible in some cases. However, these are currently the only options available. We hope that waiting for the upcoming Enscape release is a suitable solution for you. Rest assured that once it is available, you will be able to work without interruptions caused by this bug.
I am happy to inform you that the “item with the same key” error has been fixed in the newly-released Enscape 4.19.0.2748, which you can download here - https://my.chaos.com/download/build?product=Enscape
Please check if you are able to start the Envision live link from Revit without any issues using the newest versions of Enscape and Envision. If anything unexpected happens, please notify me.
Thank you very much for submitting this report and helping us make our products better!
Thank you so much and it seems to be working! I am having issues exporting a stand-alone .vrscene from Enscape though, so I’ll put in a ticket through those channels to see if I can get that resolved.
