We are running a test install of Vray 2.0, and i am getting an error of -200 when I look at the render dialog. I attached a screen capture of the window with the message.
I did a Google and Forum check, but didn’t find info on this error, or what it meant.
Thanks,
Travis
We use an environmental variable to re-path the license file location to the place shown. This worked fine with 1.5, so I am assuming it is not causing the problem with 2.0.
Hm, looks like you either didn’t update the dongle, or the license server properly; it would be best to write to our support guys at vray@chaosgroup.com - they will be able to help you out.
