I keep getting this error and no RT. ??? What is this?Then if I delete some geometry… RT works. Frustrating.
Really… is it that stupid of a question? I thought it was a bitmap performance memory issue. Nope. The scene is small, under a million polys… Anybody?
Had the same problem a little while ago.
It appeared to be a texture issue for me as once texture was changed it worked fine.
Maybe it’s still an issue??..have you tried rendering with a global material override??? This may pinpoint the problem to a texture or geometry.
Hope this helps
If you still have issues, it would be best to get us the scene to vray@chaosgroup.com so that we can look at it.
thanks for the reply. Yes, when I overide it works fine, but thats thing. Is there an issue somewhere with textures? type of texture?
Some older versions of V-Ray RT had issues with PSD textures; however, this should have been resolved since then…
Thanks for the reply, no psd textures. How do I email the scene? The zip is 188mb
Email us to vray@chaosgroup.com and our support guys will let you know how to upload it on our FTP server.
Done. Thanks.
Thanks. i am uploading my zipped file now called “structural”
Any update on the file? Anything…fustrated. Using my RT with MTL Override is kind of lame. I hope there is something that can be done.
