Loba77
1
Hello, I tried everything, without enscape, sketchup opens, but with it, Sketchup loads infinitely when opened then stops working, :!:
I have RTX 3060 12GB so I don’t think my card is the problem.
My drivers are up to date
I use sketchup 2023 + Latest enscape
Help please
@Loba77 , welcome to our Forum!
Since it seems to be related or even caused by the same problem, please check out my reply here and kindly follow the steps detailed:
RE: Enscape 3.5.2+112393 loading…
Excerpt:
I’d appreciate your cooperation in order to resolve this as soon as possible. Thanks a lot in advance.
yes totally same with me.?
GPU : RTX 3060 12 GB
RAM : 32GB
Loba77
4
Hi thanks for replie.
I tried and same result, SKETCHUP keep Freezing.
As per my previous reply which I’ve linked to:
If that makes no difference, could you please also send us your SketchUp/Enscape log files manually:
Enscape main plugin log files:
C:\Users%USERNAME%\AppData\Roaming\Enscape\Data\Logs
SketchUp plugin log files:
C:\Users%USERNAME%\AppData\Local\Temp\Enscape\Logs\EnscapeSketchupPlugin
I’d appreciate the cooperation and thanks once more in advance.
