Examples of Cloud rendering wanted
I have been rendering with V-Ray for many years now and have decided to look into Chaos Cloud rendering because animations simply take too long and the improved support from the Rhino animation tool Bongo greatly simplifies cloud rendering.
I am trying to get a feel for the speed benefits of Chaos Cloud rendering and what it costs. I miss a gallery with examples like:
* high res still images rendered per single RTX 4090 or higher vs. Cloud with times and cost
* some animations (interior, exterior, product) rendered per single RTX 4090 or higher vs. Cloud with times and cost
GPU rendering is quite good scalable, so it’s easy to estimate how much speed a 2080, 3090, 4090, or 5090 GPU provides. It must be possible to relate the power of cloud rendering to this.
Hi @Micha
We just updated the Cloud to use newer GPUs, the Tesla L4 with 24 GB of VRAM. They should be around 70% of the performance of a 4090
This change is very recent, let me know if you want some Cloud credit to test with your scenes. The Cloud should be great for rendering animations
Please keep in mind that we use 2x Tesla L4s for rendering stills on the Cloud and one x L4 for rendering a single frame of animation.
Best,
Muhammed
My PC has roughly the power of a 4090. Cloud rendering an animation would take longer per frame in the cloud than locally. But the advantage would be that 100 frames could be calculated at once, right?
So cloud rendering doesn’t mean that dozen GPUs are used for rendering? Only two GPUs for still images? Why not many more?
For example, I need up to 2 hours for HQ panorama renderings in 10000x5000. I was hoping to get such images in a few minutes.
I had considered buying a 5090 GPU and rendering with 2x3090 + 5090. That would be the power of 2.5 x 4090. With the Cloud, I would only get 1.4 x 4090.
Correct, the Cloud will engage many frames simultaneously
It will use only 2x L4 for rendering, the speed should be roughly the same as your 4090 or slightly faster
We are considering adding the option to use more GPUs per frame as an advanced option, this could help
Best,
Muhammed
Yes, speed should be the top priority, because at that point, individual freelancers are limited.
I can buy a 5090 and have 100% speed. If I buy a second one, the speed doubles. A third card might also be useful. But if you want to double it again, you need three additional cards. The first doubling was the cheapest; later on, it becomes increasingly difficult. And on top of that, most of the time the hardware would be unused.
This is where I hoped cloud rendering would come in, if someone has two or three high-end GPUs and still needs a significant increase in speed.
I see another problem for myself. I use a well-tuned frame buffer post setup. When I render an animation, I get almost perfect PNGs for each frame, which I can use directly in video editing. Am I correct in understanding that I cannot achieve this result with cloud rendering? Do I only get big exr files and/or a raw JPG preview?
You could get PNGs from the cloud in the same way as your current workflow.
And thanks for the suggestion, I will see with the Cloud team what could be done about this.
The GPU Cloud was more about rendering animations, it used to be on Tesla T4s which is a lot slower than a 4090. Now we use Telsa L4s on the Cloud very similar to an RTX 4080 in performance
Best,
Muhammed
Best,
Muhammed
Just to be sure, the PNGs would be with exposure, curve correction, denoising and lens effects?
If I have an animation that takes 3 minutes for one frame at 4090, how long would an animation with 400 frames take via the cloud, and what would be the approximate price for this?
To me it’s insane that this info isn’t clearly available somewhere. It’s like it’s some sort of secret.
I really don’t understand the obfuscation. Render farms have basic calculators to give a rough idea, so why it’s seemingly so difficult with
this is beyond me, and so the service isn’t remotely attractive from a business point of view imo.
I do agree with you!
I guess the idea is that anyone could have free credits to try with their scenes before buying. Either way, I made a note about the GPU cloud cost\frame and expected performance. I will add them to the support portal as well as the documentation ASAP
Best,
Muhammed
30 Euros or so(as tested now), you will get back your frames in around 20-30 minutes depending on the demand on the GPUs at that time
I will add some examples and cost estimates for GPU rendering on the cloud
Best,
Muhammed
That sound’s great @Muhammed_Hamed , that’s what I need. I will test the workflow. :slight_smile: Since Rhino fully supports the animation tool Bongo it seems to be a good time to start cloud rendering of animations. Thank you for your help.
Ok, that cost calculation is valuable and would be a good example of my point, and why this info should be available on the product page.
It really strikes me as odd that it isn’t, as even a rough calculation on a random renderfarm site says that their cost is significantly higher
than what Chaos offers, directly meaning that Chaos should be pushing such comparisons to drive business.
