Exception: Memory allocation failure
hello world!
I’m taking the first steps with v-ray … way!
I am, however, unfortunately also struggling with frequent mistakes, errors that occur when mainly renders the scene to size “screen” (px1900x1050)
errors that occur both in Distributed rendering that in sessions without network ..
my laptop (the D90) … should stand … 4gb ram windows vista 64 bit …
MODEL INFO
Edges 168,000
41,000 faces
istance component 750 --
component definition 78
Group 1111
(all materials are assigned to faces and not a group - component)
I think, and I hope that the problems rotate around these parametrima OF YOU WHO CAN 'MAKE LIGHT ON THEIR UNDERWEAR BEHAVIOR?
1. Global switches> render X Batch render
2. Global switches> render X Low tread pryority
3. System> Raycaster params [] max Depth [60]
4. System> Raycaster params [] min leaf [0]
5. System> Raycaster params [] Face / level [2]
6. System> Raycaster params [] mem limit [400] but I tried to raise up to [2200]
We would really need a more detailed explanation for these parameters of what is on the leadership of v-ray (for max …) and running rigira say only what is already v-ray for sk says TIPS in the screen …
provide explanations if someone really would be useful then to move the entire tutorial on …
There also enclosed the message box is where, hopefully, clues about … sorry if I post all render progress window mwssage but
I’M DISPERATE
Beginning render sequence
Preparing renderer…
Preparing scene for rendering.
startCameraTime=0.000000, endCameraTime=0.033333
numCameraTMs=2, numFrames=1, frameSamples=2
Initializing built-in VFB.
Preparing camera sampler.
Preparing scene for frame.
MtlMulti (noname) “mtls” parameter is deprecated; use “mtls_list” and “ids_list” instead.
Compiling geometry.
Bitmap file “U:\txtr\pavimentazioni.rivestimenti.intonaco.calcestruzzi\PAVEST_pietrairregolare_01_displacement.jpg” loaded.
Bitmap file “U:\LAVORI\lavori-RR\MRGH0108-Villa Baumann\FOTO\P1130981-R_displacement.jpg” loaded.
Bitmap file “U:\LAVORI\lavori-RR\MRGH0108-Villa Baumann\FOTO\MUREST_INTONACO_BIANCO_SOLCATO_D.jpg” loaded.
Preparing ray server.
Creating and initializing 2 thread(s).
Allocating memory for build data of 77043 faces (2157204 bytes, 2.1 MB).
Initializing face build data.
Creating ‘done’ event.
Starting first thread.
Waiting for thread completion.
Releasing thread resources.
Preparing faces for intersection tests.
SDTree statistics:
Total number of faces stored: 77043
Max tree depth: 33
Average tree depth: 20.3469
Number of tree nodes: 24661
Number of tree faces: 224700
Number of tree leafs: 10450
Average faces/leaf: 21.5024
Memory usage: 5.19 MB
Scene bounding box is [-2646.36,-2511.84,-242.52]-[-1183.93,-1138.67,570.44]
Preparing direct light manager.
Preparing global light manager.
Irradiance sample size is 84 bytes
Photon size is 56 bytes.
Light cache sample size is 120 bytes.
1 interpolation maps registered
Rendering interpolation maps with minRate=-3 and maxRate=0
Setting up 2 thread(s)
Bitmap file “U:\LAVORI\lavori-RR\MRGH0108-Villa Baumann\FOTO\PIETRA_baumann_rivestimento_010_B.jpg” loaded.
Bitmap file “U:\LAVORI\lavori-RR\MRGH0108-Villa Baumann\FOTO\PIETRA_baumann.rivestimento.011.png” loaded.
Bitmap file “U:\txtr - corrente\PAVEST.autoblocc.10X10.ssgiovi.jpg” loaded.
Bitmap file “U:\LAVORI\lavori-RR\MRGH0108-Villa Baumann\FOTO\lattoneriacampianata.jpg” loaded.
Bitmap file “F:\My Documents\ASG\Materials\textures\concrete\concrete-08_b005.png” failed to load: cannot open file
Bitmap file “U:\txtr\pavimentazioni.rivestimenti.intonaco.calcestruzzi\MUREST_INTONACO_BIANCO_010.JPG” loaded.
Bitmap file “U:\LAVORI\lavori-RR\MRGH0108-Villa Baumann\FOTO\P1130981-R.JPG” loaded.
Bitmap file “U:\LAVORI\lavori-RR\MRGH0108-Villa Baumann\MATERIALI\wood-17_d.png” loaded.
BitmapBitmap file “U:\txtr - corrente\PIETRA.serizzo001.jpg” loaded.
Bitmap file “U:\LAVORI\lavori-RR\MRGH0108-Villa Baumann\MATERIALI\wood-17_b.png” loaded.
Bitmap file “U:\LAVORI\lavori-RR\MRGH0108-Villa Baumann\FOTO\TEGOLI_campianati_P1130897_D.png” loaded.
Bitmap file “U:\LAVORI\lavori-RR\MRGH0108-Villa Baumann\FOTO\TEGOLI_campianati_P1130897.jpg” loaded.
Bitmap file “U:\LAVORI\lavori-RR\MRGH0108-Villa Baumann\FOTO\pietracampoanatasmap_P1130864.jpg” loaded.
Bitmap file “U:\txtr\pavimentazioni.rivestimenti.intonaco.calcestruzzi\PAVEST_pietrairregolare_01.jpg” loaded.
Bitmap file “U:\TREE\GILE[1]\ABETE30.jpg” loaded.
Bitmap file “U:\TREE\GILE[1]\ABETE30_ALFA.jpg” loaded.
Bitmap file “U:\LAVORI\lavori-RR\MRGH0108-Villa Baumann\FOTO\concrete-09_d100_rev01.jpg” loaded.
Bitmap file “C:\ProgramData\ASGvis\VRayForSketchUp\Textures\Cladding_Stucco_White.jpg” loaded.
Bitmap file “U:\LAVORI\lavori-RR\MRGH0108-Villa Baumann\FOTO\MUREST_INTONACO_BIANCO_010_solcato.jpg” loaded.
Bitmap file “U:\LAVORI\lavori-RR\MRGH0108-Villa Baumann\FOTO\LNDSCP-back_010.JPG” loaded.
Bitmap file “U:\LAVORI\lavori-RR\MRGH0108-Villa Baumann\FOTO\LATERIZ_campianato_da_lontano.jpg” loaded.
Bitmap file “U:/TREE/GILE[1]//TRNC010.png” loaded.
Bitmap file “C:\ProgramData\ASGvis\VRayForSketchUp\Textures\Tile_Various_Tan.jpg” loaded.
Bitmap file “U:/TREE/GILE[1]/chiom010.jpg” loaded.
Bitmap file “U:\TREE\GILE[1]\chiom010_ALFA.jpg” loaded.
Bitmap file “U:\LAVORI\lavori-RR\MRGH0108-Villa Baumann\FOTO\legno_rosso.JPG” loaded.
Bitmap file “U:\TREE\GILE[1]\TRNC010.png” loaded.
Threads completed
Bitmap file “C:\ProgramData\ASGvis\VRayForSketchUp\Textures\P1130994.JPG” loaded.
Exception: Memory allocation failure; 1680000 bytes requested; 1483696989 bytes already in heap; 10714624 bytes free heap space.
Exception: Memory allocation failure; 1680000 bytes requested; 1483696285 bytes already in heap; 10713920 bytes free heap space.
Exception: Memory allocation failure; 1680000 bytes requested; 1483696445 bytes already in heap; 10714080 bytes free heap space.
Exception: Memory allocation failure; 1680000 bytes requested; 1483696735 bytes already in heap; 10714128 bytes free heap space.
Exception: Memory allocation failure; 1680000 bytes requested; 1483696569 bytes already in heap; 10713720 bytes free heap space.
Exception: Memory allocation failure; 1680000 bytes requested; 1483696555 bytes already in heap; 10713696 bytes free heap space.
Exception: Memory allocation failure; 1680000 bytes requested; 1483696529 bytes already in heap; 10713288 bytes free heap space.
Exception: Memory allocation failure; 1680000 bytes requested; 1483696515 bytes already in heap; 10713264 bytes free heap space.
Exception: Memory allocation failure; 1680000 bytes requested; 1483696203 bytes already in heap; 10712560 bytes free heap space.
Exception: Memory allocation failure; 1680000 bytes requested; 1483696177 bytes already in heap; 10712152 bytes free heap space.
Exception: Memory allocation failure; 1680000 bytes requested; 1483695855 bytes already in heap; 10711448 bytes free heap space.
Exception: Memory allocation failure; 1680000 bytes requested; 1483695829 bytes already in heap; 10711040 bytes free heap space.
Exception: Memory allocation failure; 1680000 bytes requested; 1483695803 bytes already in heap; 10710632 bytes free heap space.
Exception: Memory allocation failure; 1680000 bytes requested; 1483695311 bytes already in heap; 10709536 bytes free heap space.
Exception: Memory allocation failure; 1680000 bytes requested; 1483695299 bytes already in heap; 10709152 bytes free heap space.
Exception: Memory allocation failure; 1680000 bytes requested; 1483695259 bytes already in heap; 10708720 bytes free heap space.
Exception: Memory allocation failure; 1680000 bytes requested; 1483695235 bytes already in heap; 10708464 bytes free heap space.
Exception: Memory allocation failure; 1680000 bytes requested; 1483694991 bytes already in heap; 10707968 bytes free heap space.
Exception: Memory allocation failure; 1680000 bytes requested; 1483694411 bytes already in heap; 10707136 bytes free heap space.
Exception: Memory allocation failure; 1680000 bytes requested; 1483694383 bytes already in heap; 10707088 bytes free heap space.
Exception: Memory allocation failure; 1680000 bytes requested; 1483694191 bytes already in heap; 10706432 bytes free heap space.
Exception: Memory allocation failure; 1680000 bytes requested; 1483694091 bytes already in heap; 10705616 bytes free heap space.
Re: Exception: Memory allocation failure
:cry: help me … I have to deliver the views! :-*
Is this something that is persistant within the file. IOW, if you save the file, restart your computer, and re open the file, does it still pop up. Obviously it looks to be a memory issue, so the process of restarting the machine will clear the memory, and hopefully this issue as well. I’ve seen this once or twice recently, but its never been more than isolated cases of it.
I Restart the computer often but … does not always work … if "exaggerating only slightly with LC IR DMC all goes ****
probably some geometry malignant …
in your opinion how can intercept …
I tried to explode all objects but I stopped when noticed that some faces, exploding, is united to the other …
example, exploding the railings some rods are united to the other … things of this kind …
but you could give some specific about
These values could help to resolve …
there is essentially a way to make the calculation slow but powerfull … like a tractor and not a Ferrari? ???
I’m not sure if there are any geometry check mechanisms in SketchUp. Bad Geometry, degenerate meshes, or what have you do cause V-Ray to choke on the render. There might be a ruby script that would could check that, but I’m not directly aware of any.
By default SU checks for errors on save. Setting is located under Preferences->General
And you can manually ask it to check for errors from Model Info->Statistic->Fix Problems
But that’s it. If you use that and still get errors it’s weird…
the problem is solved …
you want to laugh …
I had to deliver with some urgency then I took the laptop on vacation with me …
Here Since then no error has occurred more …
He needed vacation!
I must, however, actually say that I gave an “arranged” to the model, I exploded some group (not many in reality) and I started again CG material ruby (I swear that I had already done!)
Then, always the fault of despair mixed with haste, I tried to upload maps and IR LC that V-ray created (the mistake I made was undergoing final renderig …)
From that point, although subsequent tests and the final image has been made with IR map recalculated from scratch every time I’ve had more mistakes!
however, promise that the next time i will send my problem to the stuff (sending the file) and not the forum …
I was very concerned …
P.S. This is a picture …
Practically my first job with V-ray:
nice! I really like
Chances are there was just some faulty geometry within a group, and exploding fixed it, or one of the groups themselves were causing us an issue, and exploding fixed it.
As to not being able to use saved IR maps, that’s a known issue and we’re working on a solution for that. Its a really big issue in my eyes, so we’ll try to get it worked out ASAP.
