.EXE view settings
I’m assuming this isn’t possible, but the view settings baked into my ‘favorite views’ in the Revit plugin for Enscape don’t translate to the .exe. Is this possible? So, for example, View 1 shows just the structure and view 2 shows the entire building?
This works in Enscape via Revit, but I can’t seem to make translate through to the .exe.
Aaron
Hello Aaron - Enscape exports the favorited views when creating a standalone EXE file. However the favorite views don’t change visibility settings as if selecting the view as the active document. The favorited simply preserves the camera location and the time of day.
Thanks, That’s what I’m discovering. It would be nice to turn on/off Elements in the .exe, as all the geometry is already there.
When creating a standalone EXE file,Enscape no longer exports favorite views as before when creating standalone EXE files. (3.4.0+84039~) Is there any place I should check in the settings etc. to make the window of my favorite view appear in the exe file?
Hi @Oko_1
Welcome to our forum!
I was not able to reproduce this issue, the Favorite Views panel still shows on the right when creating a Standalone Exe file with our 3.4 version.
Is this happening with a specific project only, or in all projects for you?
