Would it be possible to expose additional camera settings please (as available in the 3Ds Max V-Ray Physical Camera for example)?
eg. focal length (as a number not just the inaccurate settings Revit has natively), aperture no. (instead of just ‘defocus amount’) and sensor size (which gives another level of control over depth of field).
Some Tilt & Shift controls would be really handy too.
+1 for this, could be also nice if through Vray camera could match viewport with background image. As far if it possible through Revit API. Revit own camera is really limited at the moment.
@FINRevitRockstar , can you elaborate a little bit more on your request? More specifically the background image matching part.
I just want to make sure if I’m getting it right.
@Ana_Lyubenova quite late answer from me… Anyway, could be nice if through Vray camera in Revit can do same than in 3ds Max camera perspective match. Of course if it is possible through Revit API to do that.
