Expotential light with a standart Vray Light and a multiplyer of 2 and Enviromental to 1 creates very nice blending of overbright ness and shadows are quite bright but the textures are very bright and the colours have to be crancked up to achieve the colour that you want, On the other hand the Linear makes all the textures and textures look nice but the shadowed areas are quite dark.
What would be the best way to render an exterior shot?
i was hoping to get something cleared out in this thread, but somehow its being “ignored”…hehe
well i used to use the exponential hsv but cause it gives u a nice control over the light-dark balance…but it removes its contrast …so now im back with the linear.
hi, latelly i’ve been only used linear in everything , interior and exterior views, what i have done to avoid dark shadows is to increase the dark multiplier in color maps, and if it let too much bleed at your scene , you can control it decreasing the saturation value there in render>indirect ilumination> saturation
oh cool tip silver. Thats in the builtin max/viz exposure control section right?
My problem is for an interior scene where the outside needs to be really brightly lit (otherwise it looks too dark through the glass), I have to crank up the direct sun multiplier, but in doing so Im stuck with needing HSV exponential colourmapping to prevent the timber floor being washed out
Tip :: to aviod loss of contrast use Linear … and low level lights … but all mats with outputs .. this way you get nice bright rooms with no blow outs.
