Can you try deleting the *.clbin file in the temporary folder (type %temp% in Windows explorer to go there) and also disabling the 285 card? If that works, try enabling the 285 card again.
Vlado, I did what you told me. With only the GTX580 it is working. In combination with the GTX285 it crashes.
I thought, VrayRT can use ANY OpenCL which is available?
BTW, iRay is running like charme with absolute no problems in this configuration (GTX580 + GTX285). I just did another test.
So 2 more questions arise:
I was planing to buy a second GTX580 to replace the GTX285. Will this configuration run? I really need 2 graficboards because I am running a 3 screen configuration with 2 x 21" monitors (connected now to the GTX285) and a 30" monitor in the middle (connected now to the GTX580).
In the next step, I was hoping to upgrade my renderslaves with cheap GTX460 2GB RAM for distributed rendering on GPUs. Is there ANY chance that something like this will run without problems?
Yes, it will do that; however in your case the cards are too different. V-Ray RT attempts to load the GPU code from the 580 card on the 295 card (the reason for this is to reduce the start up time), which fails. It can be made to work, of course, and we will look into it. There are no problems if the cards are identical, or of the same architecture (e.g. when both of them are Fermi cards).
BTW, iRay is running like charme with absolute no problems in this configuration (GTX580 + GTX285). I just did another test.iRay does not use OpenCL, so no point to mention it.
I was planing to buy a second GTX580 to replace the GTX285. Will this configuration run?Yep, it will be fine.
In the next step, I was hoping to upgrade my renderslaves with cheap GTX460 2GB RAM for distributed rendering on GPUs. Is there ANY chance that something like this will run without problems?It will run fine, yes.
Ok then, I just ordered a second GTX580 as a replacement for the GTX285. It will be delivered in 3-4 days.
I will give a statement in these thread after installation and testing then.
Problem solved with a second GTX580 as replacement
Just want to say, that the problem is solved. Today I received my second GTX580. After replacing the GTX285 with it, everything worked. And its fast. Real FAST!
