failed to create temporary file name (error 80: the file exists.)
I need your help here.
Form yesterday, I am having a trouble with rendering. Materials are not applied to
rendering image and whenever I tried to open Environment,
“failed to create temporary file name (error 80: the file exists.)” message comes out.
Rendering time got really slow..and all the materials are not showing in final image
Whats wrong here??
Re: failed to create temporary file name (error 80: the file exists.)
Please send us the scene and fill out a support ticket. This sounds like something that we need to take a closer look at and of hand I don’t know what the direct cause of this might be.
I´m having the same problem!!! PLEASE could you help me to find the solution? It´s highly important!
Problem solved…if you´re facing the same issue, you need to clear the TEMP directory. On a typical windows installation that folder is C:\Documents and Settings\All Users\Application Data\ASGvis\Temp Note that Application Data is a hidden folder.
