FINISH WORK
TRABAJO FINAL COFFE
PT+HD
Hi delkin
Finished work or a wip ? i think there are a lot of problems on your scene.
First you need to have some bump on the bricks; use a normal map.
Some of the wood textures are too repetitive.
Ceiling is curious : there are black holes above the beams, you have to put another shader here.
The proportion of the sofas are strange, compare to the chairs…
Your lighting is weird : where does it come from ? It looks like an exterior scene..
Your chandeliers are nice, you have modeled them yourself?
Cheers
Roland
Roland friendly for their insights, I’m wrong is a work in progress, will correct all your criticism and get better work, the lamps are modeled in Max
