Hello, do you have an idea about my issue, my scene is on vray render and I can visualize the fire on my render.
just see the following printscreen:
Probably your emissive volume is not named ‘heat’ but something else, temperature or burn - look in the info or geometry spreadsheet
I don’t understand… sorry
Hey @sbastien_levieux ,
I assume you’re using V-Ray 5 - we did some changes near the release date that caused an issue with the export for the emissive (fire) component of the shader. The issue is resolved for the nightly builds - I’ve messaged the support team with your email in CC so you can grab a nightly build once they provide you with access.
In case you’d rather use the official download, you could add this to the Post-Translate tab of the V-Ray Renderer ROP:
import vray
with vray.VRayRenderer() as v:
for p in v.plugins:
if p.getType()==‘PhxShaderSim’:
p.earg=1
Best regards!
@sbastien_levieux , you should keep indents in code, otherwise python won’t work.
