yep…ive just found that out too… ![]()
ill have to reserve some time this week to get my teeth to it a bit more…
Could you please tell me how did you put the decal onto the glass? When I do that, my decal is just as reflective as the glass.
TX
2pentool:
the label is geometry..therefore its just another material with different setting…but i think you could use a mixmap if you want create one without extra modelling efforts..
Geometry!? :shock: You mean the round label that says “Grolsch” is geometry!? Hmmm… it looks like only a bitmap mapped onto the side. My label was reflecting just like the glass (when I assigned the bitmap to the diffuse channel) and that’s why I was wondering how you mapped it onto the glass’s surface.
Looking good, but I prefer the first image except for 2 things: as has been addressed, it looks like you are double gamma correcting the label image… try setting your bitmap input gamma to 2.2. Also, maybe its a modeling issue, but the bottle cap looks kind of fake.
Pentool:
Have a look here, might help you.
http://www.chaosgroup.com/forum/phpBB2/viewtopic.php?t=13384&highlight=decal+glass
http://www.chaosgroup.com/forum/phpBB2/viewtopic.php?t=14713&highlight=decal+glass
To Clifton:
i fully agree…i havent had time to return to that project yet..hopefully i ll do it today between jobs
To pentool: yep …geometry…as i couldnt find out the way how to do it by textures with all the maps and uvws..thanks to you and gijss post i know now :))))
here is an update…ive converted the scene to lwf
..do you think those displacement reflection on the backside of the glass are rsupposed to be there? co i am not sure…
…does anyone have an experience with a studio lighttable setup?
i was experimenting with adding a gradient ramp in vraylightmat and applying it to the plane i am using in the image..it look ok, but i would also like to add a little reflection to the mat. how would i do that? or is it possible to combine vraylightmat and reflection together???
ive been thinking about doing it in geometry by cloning the plane rescaling slightly and giving it a semi transparent reflective mat. underneath i would have the current plane with vraylightmat with gradient ramp applied to simulate the fading light..
cheers for comments and ideas
Martin[/img]
I liked the first version(s) much better. This is too gray.
Looks goot but abit too gray, run it thru PS using something similar to the color curve below.
That will help get rid of the gray and brighten it up a little.
Should do wonders ![]()
Looks good, i like the reflections now ![]()
Ah the good old “S” curve, does wonders to your scene hehe ![]()
actually i did not apply it at all for this image, as it is a separate render with no post processing afterwards.
…it was agood tip though…thanks again daforce…
:lol:
anyway one of the guys (loocas duber)on the maxarea forum suggested comping the image in ps…addditive blending real rgbpass and refraction pass to achieve light scattering in the glass…here is the result
ill try to play with translucency a bit in the glassmat to see the difference between comping and straight render..
is there an absorbtion or volume pass planned for the next release of vray?
