Hola Sony_rojo,
Bienvenido por tu primer post. Que bueno que estes tomando parte activa en la comunidad de V-Ray para Rhino. Los parametros estan un poco bajos y el render se ve un poco blur, pero se ve bien, talves debes cambiar los materiales para que se vea un poco mas realista. Me preguntaba si has visto los materiales del V-Ray express, pueden ser de mucha ayuda a la hora de crear nuevos materiales.
De nuevo, bienvenido y mucho exito.
In first place, thanks for all, fpedrogo. I will try to do what you told me, now I show you this image. The blue ambient is because I used a bitmap of a lake for the enviroment; yes, maybe it was a mistake. But I want to get reflections on the front while I don´t get HDRI images for the enviroment. I still have problems with this part of the model. It doesn´t seem real at all.
Yes, I saw the Materials Express, but I´m working with Rhino 3 yet. I think that those utilities are very useful. Good work by the developers.
About the model, this is a part of a project that I made some time ago, it´s a power supply module for marinas. You can get more information at www.plusmarine.com.
Hi
The only thing that I don’t like, is the yellow material. I believe that you are using a bump map to give it texture. If the case should be plastic, then try this setting for your plastic.
Reflection Layer - fresnel (default and Reflection Glossiness 0.8
Diffuse Layer- your color
and if you still needed the bump map, you can use it.
Do the same for the gray color material.
I like the look of the red material and the blue material. Also if you want you can use the background map in the material editor to put the like HDR of the lake, for the metal material, instead of the environment. If you do that the HDR will only affect the metal material, not the whole scene.
