Thanks for raising this, and I understand the frustration. I want to explain what is happening today and why, and then discuss a possible way forward.
At the moment, camera properties such as FOV, projection mode, depth of field, exposure, etc. exist in two places:
- On the SketchUp side, as part of the SketchUp scene.
- On the Enscape side, inside Visual Settings.
The current logic works like this:
- If Synchronize Views is enabled, Enscape overrides its own values and uses whatever is defined in the SketchUp scene.
- If Synchronize Views is disabled, Enscape uses its own Visual Settings values instead.
However, batch rendering behaves differently. During batch rendering, Enscape always uses the Visual Settings camera values, regardless of whether Synchronize Views is enabled or not. The original idea behind this was to make batch renders reproducible and consistent, based purely on Enscape’s view and the attached Visual Settings.
That said, I fully agree that this breaks an important workflow when SketchUp scenes are used to define precise camera framing. In those cases, batch rendering does not respect the intent of the SketchUp views, which is exactly the problem you are describing.
In theory, the most flexible solution would be to allow per-scene control over whether SketchUp or Enscape camera settings should win, and store that preference with the SketchUp scene. The downside is added UI and behavioral complexity. For example:
- How long should a scene “own” the camera settings?
- If you activate a scene, then freely move the camera, are you still bound to that scene?
- If you later want to change FOV or projection in Enscape, do you first need to detach from the SketchUp scene?
These are solvable, but they introduce edge cases that need careful handling.
Taking a step back, the core question is this:
Is there value in allowing SketchUp and Enscape to have different camera properties for the same scene?
From what we see, this is largely a preference question. Some users want SketchUp to be the source of truth, others prefer Enscape’s camera settings. Forcing one model globally reduces flexibility.
This raises an important question. For batch rendering, would setting camera properties directly in Enscape be an alternative workflow for you? If that is the case, then one option is to make this behavior explicit rather than implicit. For example, we could add a clear, informative UI message in the batch rendering dialog stating that batch rendering always uses Enscape camera values.
A more pragmatic option would be to add a clear option for batch rendering that explicitly respects SketchUp camera properties for all scenes. This would directly address your issue without introducing per-scene complexity.
I would be very interested to hear your thoughts on whether making the current behavior explicit or adding an option would best fit your workflow.
