having expression seems to work on alembics but not on vdbs: example below with the first being the expression and the second the evaluated expression
path/to/file.`ch(../../parm)`.vdb
path/to/file.1001.vdb
path/to/file.`ch(../../parm)`.abc
path/to/file.1001.abc
Regards Alexis
Yup, we have it logged already - I’ll ping the dev team.
As a side note - if you’re loading with a File SOP, setting the mode to packed disk primitive and using a Wrangle to modify the instrinsic unexpandedfilename will give you the expected behavior.
Cheers!
Hey, Alexis,
the problem you reported should be fixed now. For the sake of transparency - the other one, HOU-1679, is related to the volumes getting baked when using a channels reference for the entire path, e.g. `chs(‘path/to/output/rop/diskpath’)` - this has also been fixed.
Hope that helps!
