(fixed)[HOU-2709]GPU + RTX opacity bug
Unless this works differently this isn’t working as expecting on RTX/GPU. Opacity does not work with two different materials this works fine on the CPU even as you can see before it renders the final image it shows the correct output when doing the lightcache but then it doesn’t render correctly.
If the opacity is just on the material it works fine. Maybe in the GPU this works differently and if so can you guys explain please? thanks. Attached is the HIP
opacityBug.zip (1.46 MB)
Could someone either tell me if Im doing something wrong, or there is another way to accomplish the same or this is another GPU/RTX bug? Thank you
Hello @hsz , the obj model is missing, but I tested with a grid and can’t reproduce it n my side. Any chance for the obj file?
@chakarov Sorry about that - Here it is. Thanks for taking a look
geo.zip (196 KB)
Let me know when you get chance, if this is a bug or if there is a different way to do the same, thanks
Hi, I’ve just checked it with your model.
This is definitely a bug.
Something goes wrong when two parts of the mesh get different materials. As a workaround I can suggest you to split paper and outside part in different geo nodes. Is this work for you ?
Not really for what I’m doing. I’m using Vellum and I need both pieces to be one, if I was not simulating and render as a still it would be fine. I hope this bug can get fix soon, Thanks
Any word on when this can be fixed? Thanks
This will be resolved in the next nightly.
Awesome thanks! I’ll test out and when back
Just reporting back that this is working correctly on the latest daily, Thanks again! Cheers
