This project is an entry for the Evolo 2020 Skyscraper Competition. It is one of my recent personal efforts, please enjoy! (Please find my other competition entry here [taɪd] - Hilltop Art Hotel in Turin, Italy) You can find the full exhibition board in the next post if you are interested. Also, don’t forget to share your comments and click on like, your support is really, really important to me.
FLEXSCRAPER Skyscraper Design – the Retreats for Progress
Inspired by bamboo, FLEXSCRAPER – the super high-rise building adopts a light and flexible structure. It is suitable for most scenarios where a higher floor area ratio building is required. Unlike most skyscrapers where aggressiveness is the theme, FLEXSCRAPER shows more humility, in an attempt to advocate a new attitude of mankind towards the environment in the process of urbanization.
FLEXSCRAPER is the vertical stacking of a series of frustum-shaped standard modules with high elasticity and extension. It compromises the comfort of use compared with traditional skyscrapers, which has a rigid structure system. As a result, even with an increased survival rate after significant disasters, the structure of FLEXSCRAPER is still lighter and more flexible. The designer can also add form adjustability to the standard module, thanks to the great extension. FLEXSCRAPER also compromises on its module’s independent adjustability by having them connected directly. Thus, comes a more variable building form and a higher space efficiency than those with a modular frame. To sum up the traits of FLEXSCRAPER, it would be: no stiffness is the stiffness, no form is the form, no-self is the self.
