Yes I know it’s been talked about on the forums but I still don’t have a solution to the problem..
there is this static noise effect on the displaced grass (same problem when I use Autograss) whenever I do animations - static cam movement
I’ve tried a number of things:
1. Tried different antialiasing filters
2. Disabled “View dependent” under displacement settings
3. Upped dmc settings from min samples 8 to 16 and Global subdivs multiplier to 2
4. Increased sunlight sudivs from 3 to 8
5. Played around with secondary rays bias
Still the problem persists - I’m using “medium animation preset” baked irr map (10 frames) and lightcache files, vray sun with physical cam..
Any advice?
