Flickering Hedge
It depends on your expectations. If you decide that the noise is too much it would be better to raise the AA settings.
If the quality is good enough it would be better to leave the settings as they are.
I would like to point out a few more things:
*The Image Sampler quality is mainly controlled by the Color Threshold value - if that option is too high Max subdivisions will never be reached.
*For scenes with small details like hair/fur and etc it is required to set the Max Subdivs to a higher number like 12/24/48.
*I would suggest to turn on Camera Path option in IM for this scene - it should give a better result.
*Retrace Threshold option from LC will also help to reduce the flickering but it will also increase render time.
