Ok, it is not a big deal to flip hdri or bitmap in photoshop, but anyway - would be good to know if it is always so:
I have an exterior scene. I make 360 spherical panorama from 360 corona camera to use it as environment map in 360 interior view for the same project. In the exterior scene coordinates are correct and match interior’s. Then when I load ready panorama to environment slot (Corona bitmap in CoronaColorCorrect) - it always comes horizontally flipped! Any ideas why?
It is 3ds Max that’s flipping spherical maps in U coordinates in its bitmap loader and Corona decided to conform to this behaviour, so there would be less confusion. This isn’t bug, just something you have to keep in mind and unflip spherical maps by hand.
Wait…so all maps you use as spherical environment are loaded backwards? Wouldn’t that mean sun position is always wrong for HDRI? If true, never knew this at all.
Not necessary, it’s only wrong if you’re using backplates from the same location. Otherwise it doesn’t matter - sun’s elevation remains the same, no matter if U coordinate is flipped or not and azimuth… well, 99 times out of 100, it is set arbitrary anyways :] I almost never flip HDRIs, unless i’m also using them as backdrops and they contain some text, signs or other things, which would look wrong when flipped.
@steyin: My answer would be YES, you’re right. But like romullus says, it doesn’t allways matter. Personally I always flip them, so I know whats going on
I think the technical background is that an environment is projected from a distance towards the center while the camera takes an image from the center towards distance - that’s why it’s flipped.
I think some apps automatically flip panoramic images, Max does not.
Another way to explain it is, that a sphere by default (in Max) is mapped and viewed from the outside, whereas the environment is mapped as a sphere but viewed from the inside.
Good point, yet in my case I am rendering “sphere” from the inside and then apply it on the environment also from the “inside” Mean camera see environment as physical sphere and flips it to outside in output?
You are rendering it as it is viewed from the inside, and then Max is “mapping” it from the outside. Therefore you need to flip it by setting the U tilling to -1.
