Hi Guys,
Not sure if I totally missed something or what but here’s my problems, I checked and didn’t found any answer for that.
I’m rendering an infinite ocean simulation where a huge rocks is hitting the water, creating foam and splash.
I need to render this simulation, no problem, but also this simulation as a matte object and here is my problem, the ocean no problem but the foam and splash impossible to have it as a matte object.
I tried to use right click on the PHXFoam and vray properties matte object not working, I tried with the v-ray Mtl wrapper not working, so I just tried to assign a basic vray material one the splash and foam, not working. Even if I use the Render as geometry in the PHXFoam shader.
There is no way to assign a classic v-ray shader on splash and foam without using the PHXFoam shader ? How I can have this splash/foam as a matte object in my renders ?
Thanks a lot and sorry for my English not my mother tongue I hope it’s understandable.
_3dsmax 2016
_Phoenix 3.05.00
_V-ray 3.50.03
Kind Regards,
Olivier
