Fog multiplier parameter and RT
Do you plan to make the RT reacting to changes of the Fog multiplier param ?:stuck_out_tongue:
Maya 2015/ vray_adv_30504_maya2015_x64_25511
Yes, support for Fog multiplier and color parameters will be added. I assume that you are using RT /GPU right?
In CPU mode should work fine.
No RT/GPU . Always doing RT Cpu, but I’m going to download the last nightly, I’ll keep you informed …
Thanks !
If you have problems again with your scene, please post it here for investigation (can be very reduced version of the file).
In fact the fog multiplier works well, but the fog bias doesn’t. (RT CPU) 3.15.01 nighlty 02/24
Yes, I see this already logged in our system, so it will be supported at some point.
Okay, thanks, we’ll wait some point …!
Hi Phillipe,
The fix is ready (latest build). Now the Fog bias parameter is being properly updated in RT/CPU.
Thank you very much for the info !
Have a great day.
