Hi
I have a strange problem, which I don’t think I’ve had before. When using VrayEnvironmentFog for volume lighting effects, it only works with normal rendering without a gizmo. With Vray RT it works both with and without.
Here’s a test, left image is with RT, right image is with standard Vray render, no fog! Is there some small knob that must be turned on when rendering?
Looks like the problem is the negative height value of the box gizmo - it messes up with environment fog. Change it to a positive value and everything should work fine.
