Frames rendering Cinema 4D
I have 13 frames to render, but I only want to render frames 11-13 and set this when I render for 11-13. It only renders image 11 and image 12. Image 13 is not rendered. What am I doing wrong?
Hm, I can’t reproduce this. Are you using a console command or the animation editor frame range controls? A screenshot might be helpful.
By the way, the “render offline sequence” dialog will include start/end frame inputs in the next update (finally).
Hello Mr. Pock
Can you please send us the scene to investigate as we cannot seem to reproduce the issue on our end.
Alexander
Yes I send you the Scene per mail! to forum@chaos.com
We have received the scene and found that the issue is reproducible with 1.5.3 but it is rendering correctly in our internal builds so in the next release you can find a fix or it
Alexander
