Framr Buffer dissapered
[FONT=Times New Roman]I do not know exactly what happened, I probably pulled the Frame Buffer window down and it disappeared ![/FONT]
[FONT=Times New Roman]I have closed SketchUp , restarted the computer, reinstalled V-ray – nothing .[/FONT]
[FONT=Times New Roman]When you start rendering and stand on the SketchUp icon below, you see the three icons below - SketchUp, Asset Editor, and the Frame Buffer but when you stand on the icon it does not open at the top.[/FONT]
[FONT=Times New Roman]How can it be returned?[/FONT]
[FONT=Times New Roman]It is very urgent – I can’t work ![/FONT]
[FONT=Times New Roman]I am working with :[/FONT]
[FONT=Times New Roman]Vray 5[/FONT]
[FONT=Times New Roman]SketchUp 2021[/FONT]
[FONT=Times New Roman]WIN 10 Pro 64 –bit [/FONT]
[FONT=Times New Roman]Intel Core i7-6700 @ 3.40GHz[/FONT]
[FONT=Times New Roman]32.0GB RAM[/FONT]
[FONT=Times New Roman]NVIDIA GTX 1060 6GB[/FONT]
Check this post and hopefully it should solve it Vray frame buffer off screen (3dsmax) - Issues - Chaos Forum
Thank you very much ! It helped !
Your forum is great !
Another thing that could help with issues of the V-Ray Frames Buffer is to delete FrameBufferState.fbs which is located \AppData\Roaming\Chaos Group\V-Ray for SketchUp
This issue should also be fixed in the latest hotfix.
  • Custom operating system display scale no longer causes the VFB to appear outside of the monitor bounds in some situations
