FStorm vs Corona
I was interested on this CGTalk thread,
— LINK —
This guy, with Titan X + GTX980Ti, in 18 minutes, and with his new FStorm GPU renderer for 3ds max, can obtain this image.
I’m always fascinated by new rendering engines =)
So, I converted (by hand) the scene for Corona ( I have the permission from DronK)
Next, my test, with a good, old I7 970 @ 3900Mhz. Not bad for a 4 year old CPU :slight_smile:
With a new 5960X (in overclock), we can reduce more than half the rendering time :wink:
Corona 1.3 (commercial version)
CPU = I7 970 @ 3900 Mhz
Res = 1024x1024
Pass = 130 pass
Rendering time = 30 minutes
Feel free to render this scene and write here your result.
— DOWNLOAD —
Unfortunately, the red shader is too glossy and it doesn’t match exactly the original version.
Also, the lamp intensity is too low. Sorry.
15 minutes
](http://postimg.org/image/ek3f6hi21/)
30 minutes
](http://postimg.org/image/z5i6ydzmx/)
60 minutes
](http://postimg.org/image/pyzwb3ueh/)
15 minutes
[upload
30 minutes
](http://postimg.org/image/8un6m6bvt/)
60 minutes
](http://postimg.org/image/sdwd9a015/)
Can you try embeding the picture correctly ? I can’t see them here or at cgtalk either without direct-clicking.
Anyway, very interesting renderer, saw it earlier on cgpress today. Tonemapping and Glare look very nice ! Good to see these are priority from beginning.
And now?
Now the images show up.
I would love to try optimizing this scene for Corona. I am just afraid that soon there will be some misunderstandings and hasty conclusions…
We really need glow/glare features in corona. Look how much nicer the main light, highlights and exterior is in the FStorm render.
You can do it in post. But yes, do it inside 3ds max, like in V-Ray, it can be very interesting =)
Maybe in the new Corona VFB :wink:
Doing glares in post basically nullifies any frame-buffer tonemapping (or post-production at all), since you need linear output.
Yes it’s flexible, but it pushes further the distinction that rendering “requires” ‘blackroom’ type of finishing to make complete render (not complete image).
I prefer post-production to add artistic/creative touches, not all the technical things that make render look correct and real. Renderer should work like modern-day DSLR, it should output good looking product, which may, or may not require a touch-up.
VFB+ does nice bloom, but not glare : /
Wow..this renderer looks really good and interesting. Has a lot of potential. Love the glare and glow. Just wow! Love apps that pay attention to little things like this as it reduces time and gives u a better idea of final imagery without post. U can even see the subtle glow and glare in the reflections of the other models.
Can i try optimising this scene?
Also it looks that there is one light sorce behignd first camera is missing in corona version.
About bloom and glare i think it is better when it stays out in postprocesing.
interesting test, I’m curious to see the optimized scene.
why don’t just use corona test scene to show engine capabilities instead
Because I wanted to compared the original FStorm scene to Corona.
Obviously, Corona wins. If someone with good CPU ( 5960X or Dual Xeon) can try this scene, I think in 10 minutes can obtain a clean render (with my old CPU = 30 minutes)
I don’t know how to optimize this scene. I think I did 90% correctly..
This scene has very easy lighting and shader setup.
I tested some stuff, but I am not going to post anything as:
-it is hard to compare CPU and GPU - what should we consider? Price?
-it is hard to reproduce materials - they will probably never be the same
-I could not set some things the way they are set in FStorm - for example environment - I managed to align it more or less the same way as in the original scene, but reflections are different - in FS you have this nice blueish reflection in the floor and table, I didn’t manage to get similar result in Corona
Can you put it in dropbox or anything more convenient because in free mode the dl speed is really slow
thanx
Yes Maru, of course… I know…
() My conversion is simple conversion. But it look 90% similar.
) Blue reflection is caused by the texture in the FS enviromnet. In Corona, I had only a CoronaSky. But, this doesn’t change the final result and the quality/noise.
(*) My test is just a RAW test. This scene can be called a “test-simple-interior-production-scene”. It’s for fun =)
But, it’s nice to see how a 4 years old CPU (200 euro?) can do a similar result with a Titan X + GTX980Ti.
I haven’t tried the VFB+ , but i’m guessing it applies the bloom after the render is finished or canceled/stopped. Like most other 3dsmax plugins. A nicer way would be applying it while rendering, even if with a temp lower quality or resolution. Like Octane does with the glare and bloom.
Is the Octane the only one with this approach ? Not sure how Arion / Maxwell are doing it.
You can use it interactively, just by default it is set off (only after finish), to create more fluidity.
i agree
pienamente d’accordo.
You’ll have glare in the next release.
Super looking forward :- ) Would gladly buy again
