Hi, I recently read about the GGX shader:
Are there any plans to bundle this type of shader with V-Ray?
It would be very interesting to have this type of shader built-in.
YHeaaa its fantastic!
Yes, we’ll get to that…
Funnily enough, after listening to GW’s 2nd tutorial I did a search for this too. Looks fantastic! Vlado, do you think this will be implemented fairly early on for Vray 3 ?
Yeeeiiiii , Iplement PLZ!
Yes, it’s toward the top of the list…
That indeed is great news!
I really, really appreciate the complexity of this, but it would be so useful to have this as an Brdf option in the VRayMtl shader (alongside Blinn, Phong, Ward) rather than a V-Ray plug-in, meaning complete support for all the usual suspects in the VRayMtl shader so that we won’t end up with a “crippled” shader which does not support the same attributes found in the VRayMtl or a “hidden” shader with very hard-to-understand attributes.
I don’t know if this is at all achievable, but I figured I’d just throw it in there.
I also must say, midst all these feature/enhancement requests, that you and your developers are doing such an unmatched feat with developing V-Ray and turning around user feedback into usable features. Keep up the amazing work you do! ![]()
Exactly what I’m planning to do, yes.
Thank you for the kind words!
Wonderful!
I noticed that you can create a GGX shader with Maya/V-Ray 3 if you go through this route: create → vray → create from vray plugin → BRDF material
So… may I ask why this isn’t available in the regular VrayMtl node?
It is, in the latest nightlies and the upcoming beta.
Oh, that’s absolutely awesome!
We’re usually told that Ward = best for metals while basically everything else should be really blinn.
Is this GGX method a one size fits all?
I’m no expert in this area but I would say ggx works really well for metals and sometimes other highly reflective materials.
Some examples: http://www.shlyaev.com/rnd/37-cpp-category/54-ggx
It’s a bit unlikely. It is good for metals, but you wouldn’t use it for skin, for example.
