So, I’ve had a bit of fun the last few weeks on my new ws build that I thought I’d share.
After doing research on other sites, and getting advice from members, this is the current result.
It’s not the most sophisticated build, but it is a nice and fast gpu powered build.
The MB is a supermicro x9drx with 10 pcie slots at 8 x gen 3, and an 11th at 4x gen2 i think, they all actually run at gen 2, but are plenty fast.
There are 7 x 980 ti’s classifieds, which I got for between $290-$380 each as they are evga b-stock.
Dual e5-2670 which were only $233 for the pair run the cpu computing. I was able to get 8x8Gb sticks of ddr3-1600 for $200 from natex (used server ram ecc).
Power was a bit of a challenge. The key, I believe from what I read and tested, is to isolate the graphics cards power not plugged into the MB. I have two cards in the MB running off a main evga g2 1000w psu powering the MB and CPUs. I went with powered pcie riser ribbons 8x-16x that are also powered by the main g2 psu. An extra evga g2 1000w psu powers 3 cards, an 750w psu powers 2 more cards.
The extra psu’s are always on via the tester tool, basically just a jumper, then turn on the main psu to powerup the system. I got psus that have an eco mode smart fan, so the fans only turn on when they need to. I measured the extra psu’s when on and the system off via a kill-a-watt meter pull only 15 watts…so I leave them on all tne time.
Everything runs great, and the gpus run between 60-74 degrees C.
I’m sharing this because I really believe gpu rendering is the next wave of the future, at least for animation, and I’d like to see it continue to catch attention and advance in development. Granted, I’m still pretty new to learning vray, but if those that knew hadn’t shared with me, I would be where I am now…so thanks.
