GI animation - Light flickering problem (again)
Sorry but I don’t find answer in the forum… And I don’t find answer in 3Dspot help wiki.
Here are my settings (see attachments)
I’ll post a quick-time when the render ends trough the render-farm.
I’ve got “terrible” flickering with GI…
I’m currently trying the Irrad pre-pass animation… but from now I’ve got flickering problem using it.
Hope that someone can help or post the best method to achieve animation with GI.
Method with brut force and method with irrad lightcache…
Best regards.
PS : The Irrad/Lightcache method I’m using is here :
http://www.chaosgroup.com/forums/vbulletin/showthread.php?44223-Animation-(prepass)-Flickering&p=391380#post391380
The image attached is the size of a stamp, even when I click on it.
This tut. from the help files should give you pretty good results.
I’m looking for animated GI with animated object… not for a simple camera animation.
The attachment is corrected…
Best regards
Brutforce/lightcache method :
Here is the result with those settings :
Flickering01.mov
Irradiance / LightCache :
Method from here :
AA settings for draft rendering:
Animation PrePass
Animation rendering with Interp. Frames set to 4
http://www.le-truc.ch/clients/Vray/Flickering01.mov
Pleaaaasssssseeeeeeee heeeeellllllllppppppppppp !!!
